Gigabyte Vision 3080ti and AMD 5800X fans ramping constantly.
The CPU was faulty.
AMD sorted the warranty return. Took just over a week for it to get from UK, tested in europe and back again. Not bad really.
It now is 70C during games, 50-60 while youtube and browsing etc, 30-40 when left alone for a bit.
I'll continue to try and figure out the GPU fan ramp issues.
I have found that the GPU tries to spin up the fans when it hits 40% fan speed. However the actual lower limit of the fan having enough power to spin is around 44%, so it causes a big speed ramp when they do finally come on, then they drop in speed from 44 -> 39, then turn off. Then wait all the way up to 44, and start the process over again.
To counter this I have set the fans to 44% as a minimum so they're barely audible and on all the time to prevent the annoyng speed ramps every minute.
