MX master 3 bluetooth vs wireless
frozensun
My dear friends,
Is it possible that using mouse over bluetooth option I find the mouse a little bit laggy (not so smooth) comparing to using over wireless receiver?
I mean is that possible or it's just my subjective thought.
Probably should work the same way,I woyld like for someone to explain me if there are any differences.
Please do not take offence for my apparent confusion or rudeness,it's not intent me to be like that,it's just my BPD,be nice to me,and I'll return twice better,be rude and usually I get easly pissed of...I'll try to help anyone here,as long as it's something I dealt with,and even if you think I'm rude or not polite,forgive me,  it's not me it's my BPD.
Thanks for understanding.
I forget the exact reasons why, but it is possible that the dongle has noticeably less latency than Bluetooth. They may both be over the 2.4GHz band, but the protocol used by those dongles is usually lower latency than Bluetooth which is known for its very high latency.
Engineers/anyone who knows what they're talking about feel free to correct me or add to what I said if I'm somehow right on the money.
So I was right,what I felt under the hand?
BT is usually limited to about 150Hz polling vs 500/1000/more with the dedicated connection.
F@H
GPD Win 2
