PC can't power on due to SATA power cable?
Solved by _Froyo,
17 minutes ago, Mark Kaine said:
Specs for the rest of the pc?
And did the PSU only come with one Sata power cable ?
Dell Optiplex 7010 MT motherboard with an i5 3470 and 2x4Gb DDR3.
I bought the PSU used and it came with two cables for SATA power, one clearly not the original and the other looked as though it could be. After doing some research though, it seems that the cable I thought was the original is actually not from the same PSU, so they are both meant for different power supplies. I've just ordered a cable that I know is meant for Corsair power supplies; hopefully that will do the trick.
