BSOD: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED nvlddmkm.sys
https://imgur.com/1AkmuIL
Could someone help me understand what this bluescreen is? Ive already done microsoft memory tester, everything there checks out.
This is a fresh install, also ran sfc /scannow - it found some corrupted files and repaired them.
From my understanding this is a nvidia bluescreen? Im running a rtx 3060ti with latest studio drivers, wich is also freshly installed.
i5-13600kf, 16gb Corsair 3600mhz, Asrock z690 ac itx,  RTX 3080 , 1TB+1TB PREDATOR + Western digital NVME, InWin A1, Thermalright peerless assasin 120SE
Sounds like the drivers are corrupted. Time to use DDU and install a clean pack downloaded from Nvidia's driver page.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Well, thats strange. As ive just installed windows 10 and the nvidia studio driver (from nvidia)
Let's just rule it out as usually these BSODs are related to bad/corrupted drivers, especially since the BSOD ruled out the problem residing in nvlddmkm.sys.
I think i know whats going on here. I had an undervolt profile on my MSI afterburner that was on my secondary drive. And i installed msi afterburner on the same location. And it applied the undervolt. Ill reset msi to default and see if the issue reaccures.
Why - may I ask - are you using studio (work-based) drivers on a 3060 ti (non work-based) card?
EDIT:
As far as I'm aware, studio drivers are for Quadro level cards.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
1 minute ago, Eighjan said:
Why - may I ask - are you using studio (work-based) drivers on a 3060 ti (non-work-based) card?
Because shadowplay wont work with faceit anticheat (csgo) with geforce drivers.
Ohh... sounds like a case of an nVidia "oops".  But; I'm not a streamer, so...
WHY NOT...?!
