2 minutes ago, Scheeese said:
Can someone explain if a gpu is an output device?
Are you asking about your homework?
Nah who fucking care, yes it is a form of output device.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
I tend to think output devices as something like a speaker or computer monitor. Is GPU an output device? hm... is the cpu and the intergrated graphics if applicable an output device? I don't think they are becuase whatever these output data are have to be human readable or understandable in some form.
Sudo make me a sandwich
1 minute ago, Scheeese said:
It an argument my friend and I are arguing if it is an output device
I'm with @wasab on this one. While a GPU does output data, it is not an output device. As the BBC states:
An output device allows data to be transmitted by the computer in a human-friendly form.
So the monitor would be an output device, which is fed by the GPU, but the GPU itself is not an output device. Otherwise something like a network card would also be an output device, since it transmits data in digital form, similar to a GPU.
It outputs a video/audio signal to a connected device.
The input is power and a signal from the motherboard.
Also, remember those mining cards? It's not an output device anymore technically if it has no video outputs and is just used for its processing power.
