Mixing PSU cables
Solved by Spotty,
Just now, Liborio said:On the cable from the 750 it has "type 3" on the side of the 6 pin that goes into the PSU.
The only difference between Type 3 and Type 4 cables is the 24pin motherboard cable. The cables for PCIe, EPS12V (CPU), peripheral, and SATA are compatible between Type 3/Type 4. There's no "Type 4" peripheral/SATA connector it's just Type 3.
The coloured dots indicate which type of cables the power supply is compatible with. The RMx column is the one relevant to both your RM750x white and RM1000x.
