Hi geeks,
Just curious if anyone here has built or is likely to build a PC with 2 PSUs installed. I imagine you'd have to have a tonne of power hungry components to warrant such a build. It'd be interesting to see such a setup with two PSUs in a case that can accommodate them.
ON A 7 MONTH BREAK FROM THESE LTT FORUMS. WILL BE BACK ON NOVEMBER 5th.
Advisor in the 'Displays' Sub-forum | Sony Vegas Pro Enthusiast & Advisor
  Tech Tips Christian Fellowship Founder & Coordinator
https://linustechtips.com/topic/137526-dual-psu-system-build/
Yup, a lot of Quad-SLI builds have two PSUs. Or top-of-the-notch mining rigs. Hell, I think Linus' case can fit two PSUs, although he uses only one.
I think Asus Ares had two 1000W PSUs somewhere in 2009-2010 (model CG6155).
Any unknown button should be pressed even number of times.
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1827064
Yeah - redundant PSU's :P
I think my brain switched itself off :P. Not quite sure what you mean by that?
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1827079
Nice avatar Geekazoid :)
| CPU: i7 3770k | MOTHERBOARD: MSI Z77A-G45 Gaming | GPU: GTX 770 | RAM: 16GB G.Skill Trident X | PSU: XFX PRO 1050w | STORAGE: SSD 120GB PQI +  6TB HDD | COOLER: Thermaltake: Water 2.0 | CASE: Cooler Master: HAF 912 Plus |
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1827089
2+ PSU's in the event of a failure.
Oh! Gotcha. My bad. :D
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1827090
with 1200Watt PSU's out there i cant see a reason for them to exist :P unless you also use 2 mobos :P
I agree, but there is now like 1500w (1600w peak) psu's now: http://www.pccasegear.com/index.php?main_page=product_info&cPath=15_535&products_id=14472
Cause its needed. ;)
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1827144
I've seen a lot of mining rigs with 2 PSUs, but they aren't in your standard case
Main rig: i7 3770K @ 4.54, Sapphire R9 290, Sabertooth Z77, 16 GB Mushkin Redline 2133, Lian Li PC-P50R, Seasonic 860xp Platinum, Kingston Hyper X 3K 240GB
freeNAS server: AMD Athlon II 170u 20W, 5 x 3TB WD Red in raid-z1 (12 TB)
media centre: AMD A10-5700, crucial M4 (boot), running XBMC,4 x 3TB WD Red, 3 x 3TB WD green + 2TB green in FlexRAID (17 TB)
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1830541
This is about the only reason I can think of.
As others have mentioned, with the PSU watts you can buy nowadays (1500W+ from what I've seen lately) the second is redundant.
Even a Quad-SLI build will take (usually - depending) under 1000W.
« Current PC ~ Phantom Beast »
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1830557
1000w is not really enough for 4way sli
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1834504
Yeah, it depends though.
And, as Mooshi said... I concur!  :P
https://linustechtips.com/topic/137526-dual-psu-system-build/#findComment-1837355
