PSU takes really long to power pc on.
I built my pc in 2018, specs are as follows
CPU :i5 8600k @4.8 GHz 1.30 Vcore
CPU Heatsink :NHU12S w/ Noctua NT-H1
Motherboard :ASRock Z370 Pro4
Memory :16GB Corsair Vengeance Lpx 2x8 DDR4-3000 mhz
Storage/Cache :500+250GB Samsung 850 Evo/1TB + 2(2)TB Seagate Hdd
GPU :MSI GTX 1050TI 4G OC
Case :Corsair Carbide SPEC-04 Mid Tower
PSU :Corsair CX 650M 80+ Bronze
Mouse :Logitech G304 (1.8 sens 1800dpi)
Keyboard :Cooler Master CK550 Gateron Browns
Monitor :Acer VG271U 1440p 144Hz
I got my psu (CX650M) replaced under warranty a couple of months back because it would not power on. Now its been around 5-6 months and my pc struggles to power on. I tried replacing the cmos battery and even took my motherboard for testing to the service center. The Asrock service center said it was working alright.
The PSU refuses to power the pc on when I press the power button, it will take around 15 mins or so before it works and the system powers on. Clearing the cmos does not help, it will not come on.
Is it the psu that has kicked the bucket or maybe something else?
Edit: I forgot to add, once the power supply is on it will run the pc for the entire day without any shutdown or bluescreens.
Edit 2: My motherboard is fine, there was no problem with it. The solution to the problem was to clean out the motherboard with 99% IPA. It has works flawlessly now.
