No POST when DIMMB1/B2 slots in use
Fergono
I have had this problem since 06/2020 of no POST when any RAM is in DIMMB1/B2
Running win 10 x64.  PC works find with two ram sticks in DIMMA1/A2 but will not post with any ram in other slots.
the EZ-debug mobo light for DRAM lights up & stays on.
MOBO - MSI X570-A PRO on latest BIOS  (was RMA'd to retailer who "could not replicate fault")
PSU - Antec NEO Eco gold ZEN 600w - non modular
CPU - This happened with my 3600x & now with a 5600x - even after XMP enabled in bios
RAM - 8gb sticks of G.Skill Trident Z   F4-3200C16Q-32GTZB  (tried others, same issue)
GPU - AMD 5500 XT 8GB
Storage
2x NVME WD blue SN550  500gb
3x 2.5" HDD 500gb
1x PCIe AIC (Gigabyte AORUS RGB AIC 1TB PCIe NVMe SSD GP-ASACNE2100TTTDR)
Monitors - a 34"curved 1440p viewsonic & 24"1080p IPS viewsonic .
This happens with RAM not on QVL list (thermaltake toughram Z-ONE 2x8GB R010D408GX2-3600C18A) and RAM on QVL list for mobo and CPU (G.Skill Trident Z F4-3200C16Q-32GTZB)
I have loosened the cooler brackets, tried stock cooler and nothing.  Changed case recently and re-tested every connection/plug.
Any other ideas? some AMD forum threads with same fault was reported to be a faulty memory chip.   But it cant be IMC in my case, as it happens on both my CPUs
One concern is that my PSU is non-modular, but the Mobo has an extra power socket (8 pin plug + 4 pins CPU_PWR2) & I am only using 8 pin plug.
my advice is this second power plug is only required for higher power systems than mine..
should I RMA my mobo again?   Or try another PSU?   any suggestions welcomed
First thing I would assume in this case is a bad mobo but if you’ve used it for 2 years it seems unlikely that RMA is in the picture.  I’m assuming that has been checked?
Thanks for your reply,
 I already RMA'd the board to the retailer, who claimed they could not replicate the fault.
I asked them to keep the return request open, and recently updated it as I tried it with another CPU and the fault remained. so a RMA is still possible I hope.
however they take ages, and I will need to buy a new board to use in the meantime as my work depends on this PC.
I opened a support ticket with MSI who gave some unhelpful suggestion (to clear CMOS I think)
I have tried;
 3x different kits of RAM
 2x different CPUs
checked all power plugs on everything
checked ram in every combination of dimm slot
Updated bios regularly
turned quick-boot mode off & XMP on
re-seated the CPU, RAM & GPU
tried with a new air cooler, stock cooler & without cooler
same thing happened when board was new, and after the Retailer had tested it
out of ideas..
