Deathloop problems maybe cpu
Forchy
For those of you having problems with Deathloop on pc, are you using an intel or AMD cpu? Please and thanks.
i have 2 pcs and the AMD works perfectly but the intel one has problems with Deathloop
If you're talking about the stuttering, it seems to be related to mouse input problems, controller works fine. It's apparently fixed on a Steam beta branch, but the update hasn't made its way to everyone yet.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
No , the crashing problems. A lot of people couldn’t get it to launch or the game would crash mid level. I had those problems on my intel but not my amd. Both are similar age, but one’s an i9 and the other is a 3800x.
since the ps5 is amd base hardware I wanted to see if cpu is playing a factor for anyone
