Posted September 13, 2021 Hello. For ryzen 5600x and rx 6800 xt <or> rtx 3080 build.. If i'm looking right at psu list they are from "A" list, one of the best psu's? What psu would be better? I'm looking at Gold or Platinum from "Be Quiet Straight Power 11" Is there big difference in gold versus plat? And what wattage sould be safe to use? Thanks for helping. <3<3 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Moved into its own topic, you can edit the title if you'd prefer something else. F@H Desktop: i9-13900K, ASUS Z790-E, 64GB DDR5-6000 CL36, RTX3080, 2TB MP600 Pro XT, 2TB SX8200Pro, 2x16TB Ironwolf RAID0, Corsair HX1200, Antec Vortex 360 AIO, Thermaltake Versa H25 TG, Samsung 4K curved 49" TV, 23" secondary, Mountain Everest Max Mobile SFF rig: i9-9900K, Noctua NH-L9i, Asrock Z390 Phantom ITX-AC, 32GB, GTX1070, 2x1TB SX8200Pro RAID0, 2x5TB 2.5" HDD RAID0, Athena 500W Flex (Noctua fan), Custom 4.7l 3D printed case Asus Zenbook UM325UA, Ryzen 7 5700u, 16GB, 1TB, OLED GPD Win 2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author Thanks. I simply din't want to make another "will or will not" post. But hey it's alright. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 58 minutes ago, BuilderBob said: Hello. For ryzen 5600x and rx 6800 xt <or> rtx 3080 build.. If i'm looking right at psu list they are from "A" list, one of the best psu's? What psu would be better? I'm looking at Gold or Platinum from "Be Quiet Straight Power 11" Is there big difference in gold versus plat? And what wattage sould be safe to use? Thanks for helping. <3<3 I would say they’re both pretty good if they’re on the A list. A platinum PSU will use less power when on idle. When you say 5600 & 6800xt do you mean both at the same time? Depending on the price difference and how long the thing spends idle you may actually make up the additional cost in power savings over time. As to what the differences are between the two as to its internal structure I don’t know. If it’s going to spend a long time with the 5600 alone but be big enough for a 3080, I might go for the platinum just to waste less power while I wait. Again depends on the power cost, PSU price difference, and time spent with only the smaller GPU. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 I have had good luck with Corsair and EVGA PSUs. From the A list a Corsair RMx model in the wattage range you need (850?) is a good choice. I have a 750W RM from about 8 years ago still going strong in a build my daughter is now using. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author cpu - 5600x gpu - 6800xt I just don't know which psu would be better over all. I wan't the best of best.. My old pc is ~8 years old fx8120 gtx 660.. Im finnaly upgrading and with PSU i'm stuck. I don't know which would be best and what Wattage should i get.. I don't plan upgrading for atleast 8 years.. Where i read people say 750w also? Isn't it overkill? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Just now, BuilderBob said: cpu - 5600x gpu - 6800xt I just don't know which psu would be better over al. I wan't the best of best.. My old pc is 13 years old fx8120 gtx 660.. Im finnaly upgrading and with PSU i'm stuck. Idon't know which would be best and what Wattage should i get.. I don't plan upgrading for atleast 8 years.. Ah. My understanding is that power efficiency rating has little to do with quality, so being platinum doesn’t make the second PSU more reliable, just more efficient. I don’t know what they did inside the thing to make one gold and one platinum. My suspicion is the designs are fairly similar, but I know nothing. With an 8 year life cycle the power savings of the platinum amortized over that amount of time could be significant though. My move given available data would be see what the price difference between the two is, divide that by 8, see how much power that buys, and see if the more expensive one might actually be cheaper over time. There is also the possibility that power prices will increase in the next 8 years so there’s that to consider as well. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author 30$ difference. Not much in 3000$ Build. Corsair RM750X also has two different models.. One with 135 fan, other with 140 fan? Which is better? Black/white vs Fully black label. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 13 minutes ago, BuilderBob said: 30$ difference. Not much in 3000$ Build. Corsair RM750X also has two different models.. One with 135 fan, other with 140 fan? Which is better? Black/white vs Fully black label. They're both excellent, still the one on the left (2018 version) is better (significantly quieter than the 2021 version on the right). Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 28 minutes ago, BuilderBob said: 30$ difference. Not much in 3000$ Build. Corsair RM750X also has two different models.. One with 135 fan, other with 140 fan? Which is better? Black/white vs Fully black label. To break even the platinum would have to save $3.75 a year in electrical costs. Seems doable, which would make the platinum one perhaps fractionally cheaper over time. Suspecting the 2018 is the gold and the 2021 is the platinum which would make the gold one quieter. A bit strange, because that electrical efficiency difference would change to heat making the gold one fractionally warmer. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 28 minutes ago, Bombastinator said: To break even the platinum would have to save $3.75 a year in electrical costs. Seems doable, which would make the platinum one perhaps fractionally cheaper over time. Suspecting the 2018 is the gold and the 2021 is the platinum which would make the gold one quieter. A bit strange, because that electrical efficiency difference would change to heat making the gold one fractionally warmer. Apparently, the Gold and Platinum PSUs OP was referring to are bequiet's Straight Power 11 Gold and Platinum. (All versions of Corsair's RMx are 80+Gold) 2 hours ago, BuilderBob said: Is there big difference in gold versus plat? And what wattage sould be safe to use? Thanks for helping. <3<3 Since you're planning to keep your system for the next 8 years, you don't need to oversize the PSU for future upgrades. Efficiency is irrelevant, as it does not indicate how good the PSU actually is. For a 5600x+3080 combo, a high end 750W PSU should be more than enough. The RM750x is a great one, and usually one of the best bang for the buck units out there. Let us know your budget and where you will be buying from (U.S.?), so that we can help you choose the best available option. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author I live in EU. Can get any psu.. Price wise by wattage (750w), most units - same price. Gold ~150 Plat ~170-200 Euro Isn't 750w like i said overkill? My plan was getting 650w originally. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 7 minutes ago, BuilderBob said: I live in EU. Can get any psu.. Price wise by wattage (750w), most units - same price. Gold ~150 Plat ~170-200 Euro Isn't 750w like i said overkill? My plan was getting 650w originally. Where exactly? Or can you point me to the store link where you want to buy the PSU? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author https://www.dateks.lv/en/cenas/psu-barosanas-bloki If links are allowed to post. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Choose one. They're all excellent units without issues. https://www.dateks.lv/en/salidzinat?ids=93283%2C118968%2C146595%2C146897%2C162655%2C162667%2C299726%2C339850%2C339851%2C499796%2C700215%2C700224#psu-barosanas-bloki Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 https://www.dateks.lv/en/cenas/psu-barosanas-bloki/160451-bequiet-straight-power-11-750w-80-gold-modular https://www.dateks.lv/en/cenas/psu-barosanas-bloki/682351-microstar-mpg-a850gf-850w-80plus-gold-modular https://www.dateks.lv/en/cenas/psu-barosanas-bloki/162655-corsair-750w-rm750x-80-gold-modular https://www.dateks.lv/en/cenas/psu-barosanas-bloki/339440-fractaldesign-ion-760w-80-platinum-modular https://www.dateks.lv/en/cenas/psu-barosanas-bloki/680286-enermax-revolution-d-f-850w-80plus-gold just to name some. i would get the straight power 11 or the RMX. others that are mentioned are good too QUOTE ME FOR ANSWER. Main PC: Spoiler |Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz || Test Rig. Spoiler | Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb || Just Sold Spoiler | i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb || Tier lists for building a PC. Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid. (Also case airflow matter or if you are using Downcraft air cooler) Spoiler Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid. ( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D) Spoiler Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid. (RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units) Spoiler Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money! Spoiler Storage tier List. Tier A for Moving files/ OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good. (With a grain of salt, I use tier C for OS myself) Spoiler Case Tier List. Work In Progress. Most Phanteks airflow series cases already done! Ask me anything Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 10 minutes ago, BuilderBob said: https://www.dateks.lv/en/cenas/psu-barosanas-bloki If links are allowed to post. https://www.dateks.lv/en/cenas/psu-barosanas-bloki/657962-enermax-revolution-d-f-750w-80plus-gold This is the best value for money. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 Author Okey, i selected 3 that i like the best. And are from "A" tier. (Made voting poll) Be quiet beeing cheapest. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 13, 2021 2 hours ago, BuilderBob said: I live in EU. Can get any psu.. Price wise by wattage (750w), most units - same price. Gold ~150 Plat ~170-200 Euro Isn't 750w like i said overkill? My plan was getting 650w originally. If you put a 3080 in it? imho no. I don’t know what suggested power is for a 6800. What gpu you have has a very large effect on what wattage you need. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 Author Will go Be Quiet.. They got better looking GPU wires. Each plug has own wire.. Not like Corsair who has two plugs on one wire.. Making big loop of fat wire next to GPU to connect next plug in. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 1 hour ago, BuilderBob said: Will go Be Quiet.. They got better looking GPU wires. Each plug has own wire.. Not like Corsair who has two plugs on one wire.. Making big loop of fat wire next to GPU to connect next plug in. The two plug system can work as well IF the cable is thick enough to handle double the draw. You may or may not be getting anything with the be quiet as the two cables could both be connected behind the wall of the box. Would just effectively mean the extension wire was longer. I don’t see how it could be worse though so you may have a point. Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 Author They are connected at PSU side, simply "longer" extension for each plug. No loop at gpu. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 (edited) 4 minutes ago, BuilderBob said: They are connected at PSU side, simply "longer" extension for each plug. No loop at gpu. So potato potato (or tomato tomato? ‘Potato’ has a tech meaning these days). The question then is is there enough power at the base? Edited September 15, 2021 by Bombastinator Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 Author Yes thats where im not good at.. You tell me. Will 750w do for 3080 or 6800xt (same power draw ~300-350w) If i use one plug that goes > to two plugs at gpu Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 15, 2021 Tempted to go 850w and use only 3&4 for the gpu. 1&2 have the same output as 3&4 on the 550w for the 750. Possible that if the 750 works on 1&2 you could use the 550. It’s not the only thing that uses power so there could be other problems. What I don’t know is how many amps are actually needed per though. That’s the big question and one I don’t have an answer for. Someone else might though Not a pro, not even very good. I’m just old and have time currently. Assuming I know a lot about computers can be a mistake. Life is like a bowl of chocolates: there are all these little crinkly paper cups everywhere. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
