Cheapest DIY semi-smart doorbell suggestions?
y3llowduk
I'm after a really basic smart doorbell solution. No need for a camera, literally just after a button which can send a notification to my phone or PC in the house. Only needs to work on the LAN not internet. Would be useful to have a ringer too.
Looking to do this as cheap and as hacky as possible - raspberry pi maybe?
Looking for suggestions 🙂
3770k @ 4.4Ghz @ hotter than the Sun
Be Quiet Shadow Rock 2
P8Z77-V
16GB Avexir Venom 2133
Strix 980 Ti with intel heatsink fans cable tied to it
Gamemax F15
I've been looking into this as well.
The problem lies that you would need to program the device that connects to the doorbell. (Altho i was thinking of using a ESP-01S instead of R-Pi.)
But also the app on the phone. And there lies a problem for me. I cant. Specialy since you want it fast and always on.
So i will keep an eye out for this topic. 😄
I wish you best of luck!
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
I do that. We got one of those systems with cameras and it is powered by 220VAC and board thankfully runs on 12VDC. I got a NodeMCU, single 12v relay and a buck converter (connected to 12v of the board and outputs 5v to nodemcu) I connected D6 and GND of the nodemcu to the relay and once door rings and it triggers a notification on hassio app on my phone until speaker has no sound (meaning someone answered the door). It was the easiest solution do with little time I got, its not particularly the best solution for everyone but might give you some idea.
Step 1. Get a cheap, basic but somewhat smart girlfriend
Step 2. Have girlfriend hold a button
Step 3. Girlfriend sends text when someone presses the button
Step 4. Put a ring on it, upgrade to wife
1 minute ago, helfisk said:
Step 1. Get a basic but somewhat smart girlfriend
That sounds hella expensive tho.
(lets hope the door answering machine doesnt read this... 😄 )
If he absolutely must have a ringer, costs go up significantly.
Guess a raspberry Pi will have to do then.
Thing is, what @y3llowduk is looking into, gets complicated quickly.
You want it to send a notification - 2 options come to mind;
a) get a GSM module for the raspberry, use a prepaid SIM or
b) use some sort of message relay service for an app on your phone, like Notify17
However, I seem to recall Notify17 sending mails that they were ending their services
Hmm I'm guessing there isn't going to be any semi-easy ways round this. Would be nice if you could get cheap non-wifi wireless doorbells but with little vibrating receivers you could just leave in your pocket, or wife's underwear. I've found one such product on amazon but it's 3x the price of a regular wireless, non-plugin doorbell set. Boo.
Just want to listen to music without missing every parcel and without spending £50 on a ring...
P8Z77-V
Gamemax F15
Yeah you either spend a lot of money, or put in a lot of time.
No easy solutions for home-automation unfortunately.
I have also not found an easy solution yet. heheheh
Haha, I was going to suggest a dog that likes barking at people.
Be sure to QUOTE or TAG me in your reply so I see it!
CPU Ryzen 7 5800X3D GPU EVGA 3080 Ti FTW3 Ultra MOBO Asus ROG Strix B550-F Gaming RAM Crucial Ballistix 3600 MHz CL16 32 GB PSU Corsair RM1000x COOLING Noctua NH-D15
But that would ruin the music experience. 😛
Unless (s)he can bark on the beat.
I would use an ESP and do something like what @Levent did but without Home Assistant. You could have two ESPs talking to each other with web requests. One connected to the doorbell with a relay and the other with a relay connected to a lamp.
Or with some service that can send notifications to your phone from the ESP. Doing some quick googleing, I found simplepush.io. I already has an ESP integration and it's free for a limited amount of notifications. But I have never used it
EDIT: they have an example article for the ESP8266
