When Transporting a Liquid Cooled System?
Go to solution Solved by xXxYOLOxSWAGxXx_420BlazeIt,
I transport mine every few months between homes.
i just keep it upright in the car and make sure that I go slow around corner so that it doesnt fall over. I dont empty it or anything. If it doesnt leak when its standing up why would it leak when its lying down or upside down? Just make sure your resiviour is properly closed and it should be fine.
^ yep, that would work fine.
If you worry too much you could drain your system into a jug and refill when you get to your destination. If you do that leave it upright just in case extra fluid finds it's way out.
Thanks.
