Alrighty friends, need some help here as I am having a difficult time finding one. I am building my dad an HTPC for his new apartment and want to use hardware I have on hand. However, the spaces I have to work with are confined in his entertainment center. I have 12 inches (~300mm) vertically of clearance. Horizontal doesn't matter as its 100% open and I intend to use a stock cooler I have on hand, either a Wraith Prism or Wraith Spire. I wish also for the cases orientation to be normal and intended, and not getting a normal Micro ATX tower and just laying it down. I think that would look Tacky.
I am looking for a case that fits the following:
mATX motherboard support
Full size ATX power supply support
12 inches (~300mm) or less in total height
Proper orientation/presentation of case and not just laid on its side
Preferably less than $100 but would be will to entertain above depending on the options.
I wish to not have to buy new hardware as I already have an Asrock B450m Pro4, Ryzen 5 2400g, and a 450w EVGA B2 PSU I intend to use.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1365636-searching-for-matx-case/
Silverstone GD series would be a good option
GD05 GD06
This one too.
https://www.amazon.com/dp/B00U8IS830/ref=emc_b_5_t
270 mm (W) x 212 mm (H) x 393 mm (D)
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
Just now, CWALD said:
have you considered a cube case such as this one (this one is just over 12in in Hight)
https://www.newegg.com/black-fractal-design-node-micro-atx-cube-case/p/N82E16811352047
I did, but the height is a hard limit at 12inches due to the spacing between 2 glass panes on the entertainment center.
Community Standards
"Beast Mode"
GD05 GD06
oooof, $160...
Community Standards
"Beast Mode"
silverstone SG11 is one option
thermaltake may have 1-2 that work
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
4 minutes ago, HairlessMonkeyBoy said:
This one too.
Right now the SG11 seems to be my front runner. I have an SG13 for my HTPC and love it so I would assume this will be similar, just slightly larger.
Community Standards
"Beast Mode"
I have two SG12 cases, replaced ML03 cases. The second SG12 case I wanted a SG11 but couldn't find one from a "major" retailer.  So ended up ordering another SG12 which is pretty much the same thing just a different front. They are nice cases, decent amount of room for a "small" case.
  • 1 year later...
How do you like the SG12? I've got a Newtek Tricaster TCXD40 that I was given by a friend from a video production company to repurpose into a HTPC and it's based off an older version of that case, the SG02 I believe, as it has a custom front panel with a bunch of BNC component video and audio inputs/outputs but inside it has 2 5.25in drive bays instead of one
Edited by Chippinganimal
Forgot to quote message lol
