NH-U12A or NH-D15 small case
Solved by CWALD,
I am currently using the NH-D15 and I can vouch that it is massive, with my motherboard I actually have to remove my cooler in order to reach either the lock on my GPU slot or My CPU power pins. I also have to aware of how tall the memory I buy is and am unable to fit a fan on the rear side of the cooler and a rear case fan at the same time. According to reviews, the actual cooling difference between the two coolers is minimal in practice. Going forward, if I ever have to buy another one, I would probably go for the NH-U12A although I would expect the D15 to last me for many years to come.
