16 minutes ago, adarw said:
how much percentage does ebay take off cpus?
I don’t think they pay attention to what is being sold. So likely the same as for baby diapers or whatever. Could possibly have changed.
https://linustechtips.com/topic/1362013-quick-question/#findComment-14910045
They take a percentage of the sale calculated as the final sale value. The formula is on ebay's site.
If you mean how much they take off from you buying a CPU? None.
Edit:
They take 12.55% of the final sale price of up to $7,500 and if it sells for more than $7,500 then anything over that is a fee of 2.35%
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1362013-quick-question/#findComment-14910055
Edit:
alright thanks!
|:Insert something funny:|
https://linustechtips.com/topic/1362013-quick-question/#findComment-14910176
