CPU constantly running at 4.65ghz or over
@Andreas Pedersen If you are using the Windows Balanced power plan, your CPU will slow down when it is lightly loaded. The picture you posted shows that the CPU is not lightly loaded. Something is running in the background. Utilization should not be 11% when your computer is idle. Intel CPUs will not slow down if they have something to do.
Look at the Details tab and find out what is running on your computer.
Here is how my computer looks when using the Windows High Performance power plan.
When using the Windows Balanced Power Plan, the CPU slows down because it has nothing to do.
When the C states are enabled, a slow CPU or a fast CPU does not make much of a difference. Your CPU will last a long time no matter what speed you choose to run it at.
