the title says it all. do lga 2011 cpus overclock better because they are larger and do not have any integrated graphics crap incised of them?
fo a comparison let's say the
4770k http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116901
vs
4820k http://www.newegg.ca/Product/Product.aspx?Item=N82E16819116940
and also the lga 2011 is cheaper because it doesn't come with that crappy cooler
https://linustechtips.com/topic/136003-does-lga-2011-overclock-better/
The 4829K overclocks better because it's not Haswell
[AMD Athlon 64 Mobile 4000+ Socket 754 | Gigabyte GA-K8NS Pro nForce3 | OCZ 2GB DDR PC3200 | Sapphire HD 3850 512MB AGP | 850 Evo | Seasonic 430W | Win XP/10]
Yes, I would say they are generally more overclockable than the LGA 1150 platform because they don't have that crappy thermal paste between the dye and the heat spreader and they are Sany bridge/Ivy bridge CPUs so they run cooler.
Setup Video -----------Peasant Crushing Specs----------- 4K Benchmarks
-CPU- i7 3930k @4.8GHz 1.4v -Mobo- Asus Rampage IV Extreme -GPUs- 2x GTX Titan Hydrocopper SLI -RAM- 32GB (8x4GB) Corsair Vengeance 1600MHz -Storage- 500GB Samsung 840 SSD | 2TB WD Green HDD
-Monitors- 3x BenQ XL2420T | 1x Dell U2713HM -Mouse- Steelseries Rival -Keyboard- Corsair K70 Cherry MX Brown -Headphones- Audio Techinca ATH-M50 -Microphone- RØDE NT1-A
With SB v SB-E it actually favoured the SB core, which for most people would do > 4.5Ghz, but SB-E typically tops out around 4.4Ghz for most owners.
IB v IB-E was less clear as IB didn't overclock as well as SB but IB-E also overclocked less well than SB-E.
So I suspect that Haswell-E will overclock less well than Haswell, that is the trend so far.
It would probably be less due to the iGPU, and more to do with the soldered on IHS (enthusiast processors) vs. thermal paste connection to the IHS (consumer processors).
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
Trust this guy @Cacao
He is pro LGA 2011er
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
