HELP!!!!! I want to custom water cooling system in my computer, problem is, I cant find a water block and active backplate for my GPU.
Solved by Skiiwee29,
You can also purchase them in the US at Performance PCs. https://www.performance-pcs.com/water-cooling/water-blocks/water-blocks-vga/alphacool-eisblock-aurora-acryl-gpx-n-rtx-3090-3080-gaming-x-trio-with-backplate-1.html
