Flat Lan Cable or Round Lan Cable for long distances? (15m)
Solved by brwainer,
There are 8 wires in an ethernet cable, in 4 pairs. Each pair is twisted together at different turn rates. The spec then expects those 4 cables to be in a round bundle, and some Cat6 and all Cat6A and above have a plastic guide inside the wire to keep them evenly spaced (it is cross shaped).
My point is, the specification expects a round cable, and was very specifically designed to reject RF noise. For long runs, unless you need flatness to fit somewhere (going under a carpet/rug is the only option, for example) you should use round cables.
