Artifacting Occuring On MSI Optix G271 When Running at 144hz
DriedSponge
I'm having this strange issue with my monitor, where white lines will flicker across my screen when running at 144hz. When switching to 120hz, the artifacting disappears. I think the issue resides in my monitor because I've tried a different display port cables and a different ports on my graphics card, and the issue still persists. I have another monitor that is the exact same model (MSI Optix G271) and that uses the same model & brand of display port cable and it works perfectly fine. I don't think the monitor is physically damaged because I have never dropped it, hit it, battered it, etc. I got it last December and it has been sitting on my desk safely since then. Has anyone experienced an issue like this and may have some insight on possible solutions?
Thanks in advance.
Here is an image of the artifacting, it does not appear in screenshots so I took this photo with my phone:
Remember to quote or @mention others, so they are notified of your reply
AMD Ryzen 9 5950X | Arctic Liquid Freezer II 360 | MSI B450 TOMAHAWK MAX | G.Skill Trident Z RGB 32 GB DDR4-3600 | Gigabyte GeForce RTX 2080 SUPER 8 GB
Samsung 980 EVO Plus 2TB | SK hynix Gold S31 500GB SSD | Seagate Barracuda Compute 2 TB 7200RPM HDD | 1TB Samsung 860 EVO SSD | 3x Phanteks T30-120
Corsair RM1000e 1000 W 80+ Gold Certified Modular PSU | Corsair 5000D Airflow Windows 11 Home
It could be an internal issue with the monitor itself, that is not affected by the input signals coming into the monitor.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
Damn that is quite unfortunate.
Yeah, time to RMA with MSI.
It seems to only occur once I turn on my PC. To fix it I switch to 120hz then back to 144hz. The artifacting usually doesn't return until I restart my PC again.
