should i go for ryzen 5 2600
Just now, XnonXte said:Just do whatever will do good for you, If you do want to go with Ryzen 5 2600 then it is a good option, But Ryzen 5 3600 is better, Again idk about the current price from your country, There are no shame going with Intel or AMD, Be a Fan of competition, Also fix your grammar
he's probably ESL so, i'm giving him a pass on grammar.
OP, if you just got an intel 9400f i'd just hold on to it for a while.
I think it's fine for gaming. maybe not for video editing though. i don't know what kind of workload you edit, so only upgrade if it's frustrating to compile/render.
if you're willing to spend the money you can get an x570 motherboard and slot an AMD 2600 or 3600 in it until you can afford a better 3000 or 5000 series.
or hold off even longer and save up for the next AMD generation. (it just keeps getting better)
