AW3821DW return and try luck again or keep? Uniformity and yellow tints
ColdDigital
I got my replacement yesterday for my first unit that I ordered in May. First one started glitching 5 days in and had a horrible yellow tint on almost the full right half of the screen.
The replacement doesn't have it that bad but it still noticable closer to the right edges. Unfortunately though there is dark spot in the upper center of the screen, slightly bigger than a tennis ball.
Thinking about ordering another one to try one last time (maybe third time will be the charm). Opinions? Can I minimize the mark somehow? Overall opinion on the unit?
Thanks!!
https://imgur.com/a/8rAJFo4
                                         Cold
Thanks!!
Where are you ordering the panel from?
Dell Germany, so returns are no problem
                                         Cold
Ahhh okay. What caused you to need a replacement display?
The first unit started glitching 5 days in, and had a very bad yellow tint on the right side of the panel.
This one (the second unit) - the yellow tint (closer to the edges of the screen). Its better than the first unit but still noticable. Also the dark spot in the center
Not returning it yet but thinking about it... What would you say?
                                         Cold
If you bought the monitor new I'd just exchange/return the whole thing. Because it's entirely possible there is a problem on one of the control boards.
