It will be the exact same difference between ivy-e and ivy.
same thing as the change that happened between last architectures
 Crust : Intel Core i5 4690K @ 4.4Ghz 1.45v  |  MotherboardMSI Z97 MPower  |  Fruity FillingMSI GTX 960 Armor 2Way-SLI |  CoolingNoctua NH-D15  |  RAM : 16GB Corsair Vengeance 1600Mhz | Storage : 2xSamsung 840 EVO 500GB SSDs Raid-0  |  Power Supply : Seasonic X-Series 1250W 80+Gold  |  Monitor : Dell U2713HM 27" 60Hz 1440p  |
hi
i kn0w the 4770k is the all round i7 now, but how will the haswell-e equivilant perform?
4 vs 8 cores..
around 40-50% better or more
[spoiler= Dream machine (There is also a buildlog)]
Case: Phanteks Enthoo Luxe - CPU: I7 5820k @4.4 ghz 1.225vcore - GPU: 2x Asus GTX 970 Strix edition - Mainboard: Asus X99-S - RAM: HyperX predator 4x4 2133 mhz - HDD: Seagate barracuda 2 TB 7200 rpm - SSD: Samsung 850 EVO 500 GB SSD - PSU: Corsair HX1000i - Case fans: 3x Noctua PPC 140mm - Radiator fans: 3x Noctua PPC 120 mm - CPU cooler: Fractal design Kelvin S36 together with Noctua PPCs - Keyboard: Corsair K70 RGB Cherry gaming keyboard - mouse: Steelseries sensei raw - Headset: Kingston HyperX Cloud Build Log
We don't know anything about it except its name :P
YEs we do!
8 cores
DDR4
4 vs 8 cores..
btw thats the extreme edition the equivilant ti the 4770k is the 6 core i think im not sure if it has ddr4 though
My Setup :P
Skylake: I7-6700|MSI B150 GAMING M3|16GB GSKILL RIPJAWS V|R9 280X (WILL BE 1070)|CRUCIAL MX300 + WD BLACK 1TB
its confirmed that it have DDR4, no questions about that
depending on how much of an increase and price i might add it to my dream rig list and good luck for yours
My Setup :P
leaks says:
35-40% preformence increase
DDR3: 1.6 voltage
DDR4 1.2 voltage
Also lower power eating
It also have 280 pins
and it will cost much. But i think it will be affordable for a 16 to 32 GB kit
leaks says:
DDR3: 1.6 voltage
DDR4 1.2 voltage
how about 8gb
My Setup :P
how about 8gb
well
Crucial showed their price on a 16 gb ecc memory a while ago. I think it was a mistake to show it but many saw it and it have been shared on the forums.
16 GB Ecc ram was around 400 USD, but its ECC ram, that means for server PCs and they are usually much expensiver.
Also i think for a 16 GB you would need to pay 300 USD(Non ecc)
and for 8 GB half price
well
can u run ddr3 on it?
My Setup :P
No.
well
Whats the price for 16gb ecc ddr3? And the price for non ecc? What's the percentage of increase?
That percentage will stay the same or very similar with ddr4 prices
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
No you will not be able to run DDR3 on it, I dont even think you can press it in without destroying the mobo and the ram, DONT EVEN TRY!
ECC: http://www.prisjakt.nu/produkt.php?p=1310600
NON ECC: http://www.prisjakt.nu/produkt.php?p=1517970
I got suprised, there is almost no price difference:( i heard that ECC was always expensiver but nvm..
But i hope DDR4 keeps under 750 USD, because i can max pay out 750 USD for a 16 GB kit DDR4. And i hope the CPU costs under 1000 USD.
Oh you are so overestimating the price. It will be around 250€ for a 16gb stick probably at first. When it matures it will be 200 max for 32gb kit
I don't think that much since sandy to ivy to haswell was very little in terms of  performance so i think the same will be for this generation of cpus aswell as it is the same architecture
My PC specs; Processor: Intel i5 2500K @4.6GHz, Graphics card: Sapphire AMD R9 Nano 4GB DD Overclocked @1050MHz Core and 550 MHz Memory. Hard Drives: 500GB Seagate Barracuda 7200 RPM, 2TB Western Digital Green Drive, Motherboard: Asus P8Z77-V , Power Supply: OCZ ZS series 750W 80+ Bronze certified, Case: NZXT S340, Memory: Corsair Vengance series Ram, Dual Channel kit @ 1866 Mhz, 10-11-10-30 Timings, 4x4 GB DIMMs. Cooler: CoolerMaster Seidon 240V
On a core by core basis it will probably perform the same as Haswell does, just like IB-E and SB-E before did compared to their respective cores. You do get twice as many cores and more memory (and bandwidth) but you need the right software to utilise that well.
Raw CPU performance won't be that much better, except for the fact that you can get 8 cores/16 threads. The real benefit is that the chipset supports DDR4 and SATA Express
I guess so.
