Home Network & Connection
2 hours ago, Aza_ said:Any help would be appreciated,
You really have a few ways to connect the two buildings.
1) A site to site wireless link. Essentially you will put a transmitter/receiver on each building, pointed at each other. And using the magic of Wireless the two will connect. Keep in mind these are basically two direction antennas pointed at each other, so much better than trying to get WiFi from a router or range extender which uses a omni direction antenna. HOWEVER you still may suffer from interference and stuff that WiFi suffers from.
2) Wire it up. When it comes to wiring there are two ways really to run it. One is direct burial, like one user recommended the other is to run a conduit. I myself would choose the second option only because it makes it easier to run additional cables if ever needed. ALSO VERY IMPORTANT, some times utilities are buried under ground, not sure if this happens in your corner of the world. But here in the US Power, Water, Natural Gas, and Telecoms can be buried. Where I live its only natural gas, but we have the utility locating service (811) that we call to have stuff marked. See if a similar service is available if you have buried utilities. Its all fun and games until you hit an electrical line or gas line.
Next you have to choose the type of cabling. The two basic types are Ethernet or Fiber.
Ethernet:
Pros
- Cheap
- Easily available
- Can power networking equipment if needed
- Easily to deal with and repair
Cons
- Can carry electricity meaning it can carry lightning (The 8Bit guy on Youtube made a video about this happening to him twice.
- Limited to 100m/328ft
- Should be grounded if using outside
Fiber
Pros
- Can cover a greater distance
- Does not carry any electricity as its glass
- Speed is really limited on the equipment you have on each end
- Not sure if this still holds up, but generally if you want faster than 1 Gbps Fiber was cheaper as used enterprise gear is easily available.
Cons
- Expensive
- Might not be easily available
- Fragile
- You will have to either buy media converts for each end or buy a switch that can take a Fiber cable
If this were me and I had the ability to run a wire. I would A) Use a conduit. And B) Id look in to Fiber.
