Sabrent Rocket 4.0 Plus 1Tb Health is lower than it should
Aeri_
Hello, I've built my first computer at the end of April and I've noticed the Health of my ssd is lower than it should be.
Here's my specs just in case :
  • MSI B55M pro-vdh wifi
  • Ryzen 5 5600x
  • Rx 570 (Best I could get for a reasonable price)
  • A Sabrent Rocket 4.0 Plus 1Tb
On the attached image I've noticed the health is 85%. On this drive the endurance should be 700 Tb written, I'm currently at around 4Tb which should less than 1% of it health, and certainly not 15%.
Does someone has an idea of why this is happening and if my ssd is really at 85% of it health ?
Thanks
  • Ryzen 5 5600x
Thanks
How full is the drive?
Rig: i7 13700k - - Asus Z790-P Wifi - - RTX 4080 - - 4x16GB 6000MHz - - Samsung 990 Pro 2TB NVMe Boot + Main Programs - - Assorted SATA SSD's for Photo Work - - Corsair RM850x - - Sound BlasterX EA-5 - - Corsair XC8 JTC Edition - - Corsair GPU Full Cover GPU Block - - XT45 X-Flow 420 + UT60 280 rads - - EK XRES RGB PWM - - Fractal Define S2 - - Acer Predator X34 -- Logitech G502 - - Logitech G710+ - - Logitech Z5500 - - LTT Deskpad
Headphones/amp/dac: Schiit Lyr 3 - - Fostex TR-X00 - - Sennheiser HD 6xx
Homelab/ Media Server: Proxmox VE host - - 512 NVMe Samsung 980 RAID Z1 for VM's/Proxmox boot - - Xeon e5 2660 V4- - Supermicro X10SRF-i - - 128 GB ECC 2133 - - 10x4 TB WD Red RAID Z2 - - Corsair 750D - - Corsair RM650i - - Dell H310 6Gbps SAS HBA - - Intel RES2SC240 SAS Expander - - TreuNAS + many other VM’s
iPhone 14 Pro - 2018 MacBook Air
That's the best case scenario,
A full SSD will degrade faster,you need to leave a lot of space unused for wear leveling..
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R23: 15669cb | Unigine Superposition 1080p Extreme: 3566
The drive has currently 563Gigs out of 930 of data, around 60% of the usable capacity
Hmm. That does seem strange, but I wouldn’t worry about it.
