Back to the fun of modded iso images on dodgy websites, and testing them in VM's before actually using them.
Oh joys.
PC - NZXT H510 Elite, Ryzen 5600, 16GB DDR3200 2x8GB, EVGA 3070 FTW3 Ultra, Asus VG278HQ 165hz,
Mac - 1.4ghz i5, 4GB DDR3 1600mhz, Intel HD 5000.  x2
Endlessly wishing for a BBQ in space.
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14829722
This is a good video, At lest for Asus motherboards. Just blew my mind.
Video that might be pulled from this helped me figure it out. Normal person would never figure it out. Always trying to sell something. It's built into the CPU. Don't fall for it. Did that, Windows 11 can now be installed as per future proofing.
What Microsoft uses to check for compatibility.
WindowsPCHealthCheckSetup.msi
My Asus laptop from q2 of 2020 already is compatible without BIOS adjusting. It's a Asus Vivobook. At least I figured it out. A little help from Handy Andy tech tips. LTT should also cover this. Only problem I can see is if the CMOS battery dies.
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14829726
Thinking of building a deployment image at work, so no one has to worry about a dodgey source (going to pull the iso from win insider access or another reliable/trusted avenue)
Project Gray Scale
Intel Core i7 6900k @ 4.2Ghz - Dominator 32GB DDR4 2400 CL10 - Samsung 970 EVO+ 1TB NVMe - 2 Samsung 840 EVO 1TB (Gaming and Sratch) - 2 Barracuda 2TB
Asus x99 Deluxe - MSI Aero OC GTX 1080Ti - Seasonic 760 XP² - Mod1PC Custom Cables - EKWB CPU & GPU Blocks Nickle/Plexi - EKWB D5 PWM
EKWB PE360 - Corsair ML120 (6)  - InWin 303- NK65 Entry Watermelon w/ Gat Laseron 70g (205g0 & Filmed) - Logitech G Pro x Superlight
Kanto YU2 - Sennheiser PC360 SE - Acer XF270HU
BUT DOES IT FOLD?! https://folding.extremeoverclocking.com/user_summary.php?s=&u=963814
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14830014
Anyone know how to enable TTP or TPM on a gigabyte Z390 auros pro wifi with a 8700k?
I cant find anything in my bios and I updated it yesterday to see if it would be available in a newer bios version, I did find enable secure boot the options were custom or standard I tried both modes but still nothing seems to make a difference.
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14830438
They are a bunch of Aorus boards, can you be more specific?
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14831049
Look for the "Intel PTT" for Intel Motherboards in BIOS Settings>Advanced.
or fTPM in AMD Motherboards
Obviously, this is a ROG BIOS so the location may vary per brand. But I hope you get the point.
CPU - i9-11900K
Motherboard - ROG Strix Z590-F
RAM - G.Skill F4-3600C18-16GVK DDR4
GPU - MSI NVIDIA GeForce GTX 1080 Seahawk
Case - Phanteks Enthoo 719
Storage
PNY CS3030 1TB m.2 NVMe SSD
Seagate BarraCuda ST4000DM004-2CV104
Seagate BarraCuda 120 SSD ZA1000CM10003
Seagate BarraCuda ST4000LM024-2AN17V
PSU - Corsair RM850 Gold 850watts 80+ Fully Modular
Display(s) - 24" Dell P2418HT (x2)
Cooling - NZXT Z63
https://linustechtips.com/topic/1350760-tpm-14-1-module/#findComment-14831054
