Need suggestion for a case for my PC build
MEGA18
I’d say maybe a Cooler Master case like Masterbox N200 because it looks like it works well enough
Case is 100% personal opinion. Pick on you like the look of, or pick the cheapest one available on Amazon, won't have a huge effect on performance. The only thing to really watch out for is airflow, you don't really want a solid plastic or glass front. Otherwise, just pick one with the features you want at the price point you're willing to pay. I've got the Phanteks Eclipse P350X, very happy with it.
REMEMBER:
IF YOU WANT ME TO RESPOND, YOU GOTTA QUOTE ME
OR
PUT @Fixinit1 IN YOUR RESPONSE!!!!!
Gosh, I hate it when people forget. Anyway, check out my PC below, and there's a PCPartPicker link on my profile, If you wanna see what I'm planning.
SYSTEM SPECS: Finally ditched the Pentium N3540, now I've got the following:
CPU - Ryzen 5 2400G
GPU - 1060 6GB Gigabyte G1 Gaming
RAM - 16GB DDR4 3000mhz Team T-Force Delta RGB
MOTHERBOARD - MSI B350 Tomahawk
PSU - EVGA 450BT
CASE - PHANTEKS  P350X
I will say a few things.
Try to get with mesh, you'll get better temps as a result.
Find something that is going to work for you in terms of upgrading in the future.
I really really like my LianLi RGB Mesh 2. Don't have a single complaint.
N200 is an mITX case. Author (OP)'s board is an mATX
Edit: I was thinking of the NR200. N200 is the older mATX case. My bad!
30 minutes ago, MEGA18 said:
Hello, I have made a PCPartPicker list for my build but I don't know what case to pick.
PCP list: https://pcpartpicker.com/list/JCjmMv
Thanks in advance!
What's your case budget?
Edited by TVwazhere
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
I prefer big towers, I don't care about RGB, so sounddampening it is for me... Nanoxia 5, or Fractal Design Define XL V2 (nearly the same cases) or the new Fractal Design Define 7 nice too... the last one with optional glass/window panel...
but like TheStyne said, own likeing is very important. You gatta look at the monster you build =P
In the tower up to the elbows, lots of room etc...
Main System:
Anghammarad : Asrock Taichi x570, AMD Ryzen 7 5800X @4900 MHz. 32 GB DDR4 3600, some NVME SSDs, Gainward Phoenix RTX 3070TI
System 2 "Igluna" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
System 3 "Inskah" AsRock Fatal1ty Z77 Pro, Core I5 3570k @4300, 16 GB Ram DDR3 2133, some SSD, and a 2 TB HDD each, Gainward Phantom 760GTX.
On the Road: Acer Aspire 5 Model A515-51G-54FD, Intel Core i5 7200U, 8 GB DDR4 Ram, 120 GB SSD, 1 TB SSD, Intel CPU GFX and Nvidia MX 150, Full HD IPS display
Media System "Vio": Aorus Elite AX V2, Ryzen 7 5700X, 64 GB Ram DDR4 3200 Mushkin, 1 275 GB Crucial MX SSD, 1 tb Crucial MX500 SSD. IBM 5015 Megaraid, 4 Seagate Ironwolf 4TB HDD in raid 5, 4 WD RED 4 tb in another Raid 5, Gainward Phoenix GTX 1060
(Abit Fatal1ty FP9 IN SLI, C2Duo E8400, 6 GB Ram DDR2 800, far too less diskspace, Gainward Phantom 560 GTX broken need fixing)
Nostalgia: Amiga 1200, Tower Build, CPU/FPU/MMU 68EC020, 68030, 68882 @50 Mhz, 10 MByte ram (2 MB Chip, 8 MB Fast), Fast SCSI II, 2 CDRoms, 2 1 GB SCSI II IBM Harddrives, 512 MB Quantum Lightning HDD, self soldered Sync changer to attach VGA displays, WLAN
My budget is $50-$70
mATX
MB311 ARGB
NR400
Versa H18 TG*
Focus G Mini
PS15 RGB
ATX
P300A*
4000D Airflow
P360A
Focus G Blue Gray
MX330-G Air
Fara R1*
Cases with astrisk's are cases with only one fan, recommend to purchase an additional fan at minimum.
mATX will give you a smaller overall case, ATX will give you future usability of the case if you wanted to upgrade your system in the future and wanted to go with an ATX board.
