Starting my first build need help :)
Solved by Guest,
10 minutes ago, Alienware 15 R2 said:I can recommend you parts.
Core i7-4790T
Any deceant or mid range motherboard.
GTX 1660Ti or a 1060 6Gb
650W 80+ White PSU
Any Case that fits a ATX size motherboard.
1 1Tb HDD
1 128Gb SSD SATA
Anything that fits a 1150 socket i.e water cooling or air cooling.
mouse
keyboard
cheap monitor 1080p
Why would you go for such an old platform? You could get something like an i5-10400F and an LGA 1200 motherboard for the same or less, and it'd knock the socks off of an old Haswell i7.
Just makes no sense.
