Some advices to choose between 2 motherboard
Solved by Guest,
19 minutes ago, Ma4x said:
Last question,
You think the B450-F Gaming II would be better than the B550-A-Pro then ?
As it is 20 Euros cheaper then yes. Only advantage for B550 is pcie Gen 4 for the gpu and top ssd. Not really that important unless you want a Gen 4 SSD or an RTX 3090. Even then you wouldn't notice any difference in performance for the gpu.
