PC doesn't start, need help asap
Go to solution Solved by Ombiax,
It was the Motherboard Battery. The little one. That's all.
Thanks for all your help.
Hi,
So I have an older machine which I got from my brother, who was a little rough with the little one.
Every time i cut the computer off the power for a week or so, it won't start, when pluged in again.
Normally, I just push in most of the visible cables to see if they are in correctly and then it works.
Now it doesn't.
I have a green LED on my Mainboard which lights up, but the PC won't start.
https://linustechtips.com/topic/1347395-pc-doesnt-start-need-help-asap/
Is there no response after pressing the power button? Or do the fan start up and then shut off?
It may be worth checking the power button connector and making sure it is secure.
Sorry I probably edited my post. Refresh plz. Build Specs Below.
System
  • CPU
    Ryzen 9 5900x
  • Motherboard
    ASUS ROG STRIX X570-F
  • RAM
    32 GB (2X8) Trident Z Neo 3600MHz CAS 16
  • GPU
    ASUS ROG STRIX RTX 3070
  • Case
    Corsair 4000D Airflow
  • Storage
    Sabrent 1 TB TLC PCI 4.0 NVMe M.2
  • PSU
    NZXT C850 Gold PSU
  • Display(s)
    BenQ MOBIUZ EX2710Q 27"
  • Cooling
    Corsair H100i RGB Pro XT 240mm
  • Operating System
    Windows 11
No response at all.
I tried checking the connector, even unplugged and replugged it.
I even tried starting it with a screwdriver, but I'm still new to all of this ^^'
PSU Tier List   AMD Mobo Tier List   SSD Tier List
If your issue is resolved, please share the fix with the community.
Are you shorting the correct pins? Should say power switch on the mobo.
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
19 minutes ago, Tech87 said:
It's not dead, at least I guess so.
The LED of the MB is lighting up, so at least that connector isn't dead.
Replugged every power cable.
Still nothing
Unplug those other cords and just short the PWR SW pins. I would join a call but I'm currently on call for my job.
GAMING RIG:
CPU: i9-14900k
