So I want to enable ray tracing in Minecraft, but as soon as I do, the entire scene turns into a blue and green garbled mess (see attached screenshots). Unfortunately the only other game I can test that supports ray tracing is Fortnite, which outright crashes as soon as I load into a map. However, when I plug in my old 2060 into my system, both games can run with ray tracing without any issues. I suspect that maybe this is a hardware issue and I've already submitted a ticket to Nvidia (currently awaiting response), but if anyone here has any potential fixes, please let me know. System specs are as follows:
Mobo: ASUS TUF Gaming X570 Plus (Wi-Fi)
CPU: AMD Ryzen 5 3600
GPU: Gigabyte RTX 2080 Gaming OC
RAM: 2x8GB G.Skill Trident Z RGB 3200MHz
PSU: EVGA 700W BR (80+ Bronze)
All hardware is running at stock speeds, no overclocking.
https://linustechtips.com/topic/1347125-rtx-2080-ray-tracing-problem/
Hate to say it, but I agree with you the card probably broken. Good luck on the RMA
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
Beyond trying a manual uninstall of Nvidia drivers THEN using DDU (DisplayDriver Uninstaller to remove junk/old/whatever bugs and starting fresh again driver side with nothing) and then reboot and reinstall Drivers..
Beyond that... I'd RMA after that.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
24 minutes ago, eNVy1294 said:
I got the 2080 used off ebay last year, I'm not sure RMA'ing is even an option
Even non-working 2080's are selling for like $600-$800 USD on eBay right now.
Selling it might be your best bet, just use your 2060 until the GPU market cools down later next year.
[Main Desktop]
CPU: AMD Ryzen 5 5600X  GPU: EVGA RTX 3070 Ti (FTW3 Ultra)  MOBO: MSI Gaming Pro Carbon (X470)  RAM: G.SKILL Ripjaws V DDR4-3600 CL16 (2x8GB)
COOLER: Arctic LiquidFreezer II 280 STORAGE: G.SKILL Phoenix FTL 240GB SSD, Crucial MX500 1TB SSD, Toshiba 2TB HDD, Seagate 4TB HDD
PSU: EVGA GQ-1000W 80+ Gold  CASE: The MESHMOD v1.0 (Custom Deepcool Matrexx 70 chassis)  MONITOR: AOC 24G2 144Hz (IPS)
MOUSE: Logitech G502 HERO (wired)  KEYBOARD: Rosewill K81 RGB (Kailh Brown)  HEADPHONES: HiFiMan Ananda, Drop x Sennheiser HD6XX
IEMS: 7Hz Timeless, Tin Audio T2, Blon BL-03, Samsung/AKG Galaxy Buds Pro  STUDIO MONITORS: Mackie MR524, Mackie MRS10  MIC: NEAT Worker Bee
INTERFACE: Focusrite Scarlett Solo  AMPLIFIER: SMSL SP200 THX AAA-888, XDUOO XD-05 Basic  DAC: SMSL Sanskrit 10th MKII (upgraded AK4493 Version)
WHEEL: Logitech G29 + Logitech G Shifter
[Stream Encoder]
CPU: AMD FX-9590  GPU: Sapphire R9 390X (Tri-X OC)  MOBO: ASUS Sabertooth R2.0 (AM3+)  RAM: G.SKILL Ripjaws X DDR3-1866 (2x8GB)
COOLER: EVGA CLC 280 PSU: MSI A750GF 80+ Gold CASE: Phanteks P400A Digital
[Garage]
CAR: 2003 Honda Civic Coupe LX (EM2)  ENGINE: D17A1, planned K20A2 swap  INTAKE: DIY Solutions Short RAM  HEADERS: Motor1 4-2-1 with Cat-Delete
EXHAUST: Yonaka 2.5" Cat-Back with 3.5" tip (YMCB-CIV0105)  COILOVERS: MaXpeedingrods adjustable  RIMS: Core Racing Concept Seven Alloys (15x6.5)
RECEIVER: Kenwood DPX304MBT  SOUND DEADENING: Damplifier Pro Deadening Mats  SOUND DAMPENING: Custom solution, layers of thick insulation
DOOR SPEAKERS: Kenwood KFC-P710PS 6.5" Components  WINDOW LEDGE SPEAKERS: Kenwood KFC-6996PS 6x9" 5-Ways
I just installed and ran 3D Mark Port Royal to test my card's ray tracing capabilities. It went through the test just fine with an average score of 6318.
Dunno if that means anything, but I'm confused as to why it can run a benchmark but not a game.
