Audio settings guide for the Eq of logitech g pro x
I bought logitech g pro x headset wired version today. So how should I set the eq for this headset? I mostly play warzone and pubg sometimes apex .
Depends on the sound you’re going for, if you want a less modified sound, take this graph and set your EQ up to basically cancel out all its peaks and dips.
https://www.rtings.com/headphones/1-4/graph#911/3992
If you want a more bassy sound, up the lower frequency sounds a little, that’s generally pretty preferable for gaming.
For me personally, the mids and treble look fine but I would definitely try my best to flatten out the lower mids and upper bass a bit, that hump can sound extremely annoying in some cases because it’ll make low background instruments sound much louder than intended.
