Lian Li Strimer Plus connected to iCue
Zeorth
Hey,
So I recently got the Lian Li Strimer cables for my pc and I want to sync them with my corsair icue system which is already in place, is there a way to do this and if so, how?
There is 2 different ways to do it
One is via software (but this is only if ur other hardware will support it). Its called Jackned RGB sync, and it makes alot of hardware from other manufacturers talk with Icue.
Another way is to replace the connectors and hook it up to the RGB on a Node core or commander core. This will require you to cut of one of the connectors and put a standard ARGB header on it.
