CPU temps reaching 100°C on laptop
7 hours ago, Kumar114 said:run the CPU at its base speed (2.4GHz)
You can use ThrottleStop to run your CPU at any speed. No need to reduce your CPU speed all the way down to 2.4 GHz. There is no need to completely disable Intel Turbo Boost. You can either open the ThrottleStop FIVR window and adjust the Turbo Ratio Limits lower or you can go into the TPL window and you can adjust the Speed Shift Max value lower. This allows you to reduce the amount of turbo boost without completely eliminating all of it.
7 hours ago, Kumar114 said:92-95°C
These are normal operating temperatures for Intel CPUs. It is not unusual for gaming laptops to run continuously for hours at these temperatures. If you feel this is too hot then run your CPU at 3.6 GHz instead of 4.0 GHz. That should be enough so your CPU stays mostly under 90°C. Long term, consider replacing the thermal paste every six months or once a year. Post some screenshots of ThrottleStop so I can see how you have the program setup.
6 hours ago, NelizMastr said:Intel spec rating the chip for 35W
The 9300H has a 45W TDP rating. Most laptop manufacturers limit these mobile CPUs to the TDP rating, 45W.
6 hours ago, Roswell said:while gaming it definitely shouldn’t be staying at 4Ghz.
Of course it should. When 3 or 4 cores are active, as long as a 9300H is running within the rated TDP, it should be running at 4.0 GHz. That is the Intel rated speed.
