gpu overclocking help (GTX 1070)
By
Lowonley
in Troubleshooting
in Troubleshooting
Solved by Meczox_,
What SorryClaire said is basically nearly everything but i also suggest on top of all that to check some turtorial on youtube as it will be a guide which will make it easier also if you want try checking out undervolting it can help with heat
smush ·
Posted in CPUs, Motherboards, and Memory2 -
asdasdasdasdasdasd ·
Posted in Hot Deals1 -
RipperDoc5456 ·
Posted in Troubleshooting4 -
Nebcs ·
1
FancyPants101 ·
