I just bought a 6800xt. But the GPU sag was severe so I used my key cap.
  • CPU
    9900KS @ 5.0 avx offset 0/ cache 4.7/ @1.33v
  • Motherboard
    asus strix ROG z390-i
  • RAM
    8gb x2 G.skill ddr 4 3600 (OCed to 4000 17-19-19-39 @1.4v)
  • GPU
    Asus Strix OC RTX 3080 10GB
  • Case
    Corsair 280x Crystal
  • Storage
    1tb Samsung SSD + 2x (512gb Samsung) SSD
  • PSU
    Seasonic GM 650 650Watt Gold (semi-modular)
  • Display(s)
    LG34gk950g
  • Cooling
    H115i platinum/ 2x NF-A14 (GPU intake)/ 2xNFA14 (H115i radiator exhaust fan) 2x Corsair ML PRO 140(front intake) / 1x NF-A8 (exhaust)/ 2 x Corsair LL 120 (GPU deshroud fans)
  • Keyboard
    Corsair K70 LUX MX RED/ Microsoft Designer Keyboard Bluetooth
  • Mouse
    Corsair Harpoon RGB
  • Sound
    Audioengine A2+/ Audioengine d1 dac/ B&O h6
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/
*slow clap*
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14758586
Hopefully that keycap holding tight
Also why are you using 80mm (92mm?) Fan on exhaust, nothing wrong just curious
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14758643
using 80mm. It should be 60mm but the noise was too annoying. I used to have two 80mm cable tied up there before but the AIO does not allow two to be installed.
Yeah, GPU generates a lot of heat. Having a exhaust there helps with thermals.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14758700
1 hour ago, Murasaki said:
It matches the cable color so I'd say its a good solution!
thanks but my I think my entire PC looks hideous. I hate the red cables. I hate the brown noctua fans.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14758716
This is why I like the design of the founders edition cooler. It actually ejects a good amount of the exhaust right out the back of the machine instead of circulating it in the computer. Wish it did a better job with the ram temps though and other manufacturers to adopt a similar design like blowing through the card.
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14759074
The reference blower style is nice for computers that do not have an exhaust. But I think anyone willing to spend upwards of 500USD has an exhaust fan. Even with this tiny 80mm, the open cooler design is far more efficient than the blower cards.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14760282
Sorry, I should have specified 30 series founder edition. Where the front fan blows vertically through the card up to the processor and the back fan acts like a blower out the back.
Exhaust fans do help remove hot air but it has to make it up to there first.
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14761067
The key cap was too ugly so I did a different mod. This is still ugly but less of an eyesore than the red key cap.
  • CPU
  • Motherboard
  • RAM
  • GPU
  • Case
  • Storage
  • PSU
  • Display(s)
    LG34gk950g
  • Cooling
  • Keyboard
  • Mouse
    Corsair Harpoon RGB
  • Sound
https://linustechtips.com/topic/1341483-gpu-sag-and-key-cap/#findComment-14761621
