First time custom loop watercooling build
Solved by bowrilla,
6 minutes ago, Chimmie said:if the ddc pump is gonna manage the entire loop
Yes. People fuss too much about flowrate and multi pump builds. One pump is basically always enough. Sure, you won't do harm with more, but one is enough. I'd go so far and say: even an SPC would be enough (since I run a SPC pump with 2x280mm radiators, GPU + CPU blocks.I even run blocks and radiators in parallel cutting flow rate in half.
