Should I stream using my CPU or GPU with these specs?
Solved by JamesTheFolf,
4 minutes ago, PinkyPink said:I have a GTX 760, 16GB Ram, and an i5-10400f. Should I stream using my GPU or CPU?
I'd say to stream using your CPU, cause your GPU isn't super powerful and if you are streaming games your GPU will be pretty tied up with that. Honestly tho you would have to do a little bit of trial and error to find the best balance of settings.
Featured Topics
MiszS ·
Posted in Programs, Apps and Websites1 -
1
IR76 ·
Posted in Networking3 -
Blasty Blosty ·
Posted in Audio6 -
c0mplexx* ·
Skelitor ·
Posted in General Discussion6 -
1
