I have a HD 7870 right now and I was wondering will I see a noticeable difference if I upgrade to a GTX 760 or a FX 8320? Particularly in BF4
CPU: AMD 3600 GPU: ASUS DUAL OC RX 6750 XT MOBO: Asus Prime X570-P RAM: 16GB XPG Gammix D10 3000Mhz
PSU: Gamdias Kratos P1 650w 80+ Gold OS:Windows 10 pro Case: 4U Rackmount  HDD/SSD:Seagate 8 TB/ Patriot Scorch m.2 512GB
You can't spell ignorant without IGN...-TheSLSAMG
https://linustechtips.com/topic/133932-will-i-see-a-difference/
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782346
No.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782353
I get lower fps than my friend with a GTX 660 ti and a i5 3470 with the same settings though?
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782356
I have a HD 7870 right now and I was wondering will I see a noticeable difference if I upgrade to a GTX 760? Particularly in BF4
you will see around ~20% improvement in BF3
If your grave doesn't say "rest in peace" on it You are automatically drafted into the skeleton war.
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782358
I get lower fps than my friend with a GTX 660 ti and a i5 3470 though?
What are your and your friend's full specs?
Are you both oc'ing?
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782360
Full specs are in my sig
His specs are
I5 3470
Asus GTX 660 ti Direct CU II non OC
Gigabyte B75-d3h
Corsair Vengence 8GB 1600 Mhz CAS 9
1 TB WD Blue
XFX 550w
Also his i5 does not boost
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782369
His specs are
I5 3470
Gigabyte B75-d3h
1 TB WD Blue
XFX 550w
Are all your drivers up to date?
How are comparing fps?
Again, are any of you oc'ing the graphics card?
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782381
Drivers are catalyst 14.1 for me an older driver for my friend
I ask him while we are playing like Im getting 40 FPS what are you getting? 60 FPS
And no one is OCing the cards.
Its seems like he is get 60 FPS all the time while Im getting dips to 30-40 FPS
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782399
Are you doing this while both in the same game?
You should be oc'ing btw--it's very, very easy to do and gives a nice boost in performance.
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782408
I've tried OCing with afterburner to 1100 Mhz, +20% power and the card will go to 1100 Mhz sometimes but for the most part it stays at 1000 MHz. Which is odd.
EDIT: Thought I'd also mention I'm using a Arctic Cooling Accelero Mono Plus cooler on my card so it is not heat considering the card only gets up to 50C max on Furmark
https://linustechtips.com/topic/133932-will-i-see-a-difference/#findComment-1782420
