PC boots straight into bios after going into sleep... Please Help
Solved by Tech87,
Did a quick search online and it appears that may be caused by corrupt security settings.
Try removing your PIN, restart the system, and then setup a new PIN and test.
aren332 ·
Harry_rn ·
Posted in Troubleshooting0 -
2
1
kim921 ·
Posted in Build Logs2 -
_y0sh ·
Posted in New Builds and Planning3 -
James Jonathim ·
Posted in Troubleshooting1 -
6
DoDoTheGoD ·
Posted in Graphics Cards4
