New build wont startup, help please
Solved by em_lab,
the problem was that the handle of the socket x570 was not locked !
a very weird situation because i do all for it
but even if i double check that the cpu was locked into the socked it was not...
when i start to prepare the disassembly and try to remove the cpu heat sink it came off with the CPU then i saw the problem..
i put all in place again and the pc start for the first time
eureka
