My mic is detecting my output Logitech G Pro X
Solved by ChaoticChaosx,
Is your volume 100%?
I have just ordered this headset so I can't say quite yet. I know some razer headset had the same problem.
For the mic on the razer ones I use a noise removal such as Nvidia broadcast. It's quite strong but it picks up very well only when speaking. Also can try adjust in the software in your case blue voice. If there are noise gate options. You'll have to play with to get exactly where your voice is. I have a very soft one myself so took me over an hour in OBS. Haha
As well as what @TheCoder2019 has said.
