Using TV Speakers with logitech speakers
THE_GUY.
Ok, so I got logitech speakers, and I'm using my TV as a monitor, and since the TV has built in speakers, I'd like to use both systems at the same time, my TV (connected through HDMI) and my speakers (connected with a jack)
How would it be possible to use both systems simultaneously?
What Logitech system is it? If it connects with an aux cable, depending on the TV settings you should be able to plug the Logitech system into the TV audio out and have sound through both the TV speakers and Logitech speakers.
