I would choose the hyper 212 for $8 dollar more....
01110100 01101000 01100001 01110100 00100000 01110111 01100001 01110011 00100000 00110111 00110000 00100000 01101001 01101110 01100011 01101000 00100000 01110000 01101100 01100001 01110011 01101101 01100001 00100000 01110011 01100011 01110010 01100101 01100101 01101110 00100000 01110100 01110110
Audio Interface I/O LIST v2
LTT has a CPU Cooler TIer List
I'd rather go for the GM 400 Pro as opposed to the H212 (h212 has a sleeve bearing and isn't that great for the price either)
Consider the SE 224 XT @ 35 USD for non rgb and for rgb I recommend the Vetroo V5 @ 30 USD
These will perform similar and in some cases better for a cheaper cost.
47 minutes ago, Tan3l6 said:
That isn't available in my country thanks for the suggestion tho
I'm confused iCypticx, Liam can u send me the link of the tier list
The TIer List is here, they perform very similar but I'd argue that the the H212 has a poor quality bearing. See if the SE 224 XT or Vetroo V5 is available in your country. I'd go with those options out of the Gammax 400 and the H212
If I would overclock would any cooler of those fit well? My budget is 50$
