Water Calculator
Go to solution Solved by IkeaGnome,
Sooooooooo like this?
I was thinking about making a calculator using logic gates. An example would be as follows:And Gates Using Water Physics
The water would flow, and hit the other water stream causing it to go straight down into the both stream. The only problem is that there is a lot of water loss. I have figured out a way to wire them all up. All I need is a way to decipher between which one was put in if just one, and if they both were put in. If somone could link an image of a reliable way with minimal water loss that would be amazing. Thanks
By the way, I am making this out of my own curiosity, and hopefully once I get a physical copy of it, I will make a YouTube video about it. I will include the names of the people that help me with this unless you ask not to be in it.
https://linustechtips.com/topic/1331381-water-calculator/
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1331381-water-calculator/#findComment-14682879
Omfg that wet inside parody logo made be crack up.
I could use some help with this!
please, pm me if you would like to contribute to my gpu bios database (includes overclocking bios, stock bios, and upgrades to gpus via modding)
Bios database
My beautiful, but not that powerful, main PC:
prior build:
https://linustechtips.com/topic/1331381-water-calculator/#findComment-14682896
1 minute ago, The_Vaccine said:
lmao I instantly thought of that when I saw the post. glad to see another person watching steve. very underrated.
Yes. I love him. I think I saw that before and subconsciously was trying to re-create this lamo
https://linustechtips.com/topic/1331381-water-calculator/#findComment-14682931
That's kind of what I figured. Video is new and fresh in your mind if you did see it.
Him and Smarter Every Day are both awesome.
Project Hot Box
Oppbevaring
https://linustechtips.com/topic/1331381-water-calculator/#findComment-14682997
I personally like Smarter Every Day a lot better than him but he is still good.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
https://linustechtips.com/topic/1331381-water-calculator/#findComment-14683301
