monitor arm question
Solved by Analog,
24 minutes ago, tuunade98 said:Hi all,
Just got a question about monitor arms... if a monitor arm recommends 13 - 32inch and allows up to a max weight of 9kg but I got a 34 inch ultrawide monitor that weighs 5.6kg. Do you guys reckon it will be safe to mount the monitor on this monitor arm?
I already have this monitor arm was using it for my old monitor and am just wondering if it can be used for my new ultrawide. I use an electrical standing desk as well.
As long as it is under the max recommended weight specification it should be fine.
Just look what Linus did here:
