help with ikea custom desk
omniO
is it possible to get a karbly kitchen counter top with the alex drawers and still be able to adjust the height? do you need a certain bracket? is this even possible? also do you need a bracket for the desks with drawers?
Yeah just go to ikea and purchase them separately.
Get an Olov adjustable feet or finvaard.
does this work with the alex drawers? will i be able to adjust the height?
What do you mean work? You can buy them separately and make it work by yourself.
Yes you can adjust the height, just read the min / max height, see if it suits you.
I'm sorry, this is what I mean: I want to be able to adjust the height occasionally like you can with standing desks and I wanted to know if I could achieve this even if I went the drawer route
The drawer just sits under the desk on the floor. If you want standing desk options just get legs that allow you to move it up or down.
I might do that. to be honest I just wanted the drawers because I thought they might offer more stability and allow me to put my computer on top of the desk with my two monitors
"adjustable" can be 2 things, auto or manual.
Auto adjustable like motorized or hydraulic is very expensive.
Manual look like this. You have to flip the table to adjust the feet.
You can't have both. Either you get an adjustable desk on legs. Or you get a piece of wood that is put on drawers. It's an either or not both situation in terms of putting it on something.
I see, thank you
I would like to apologize. We aren't allowed to give good directions.
Place top on bottom. Glue to cabinet. Put jack under. Lift.
/s
I couldn't resist avoiding an Ikea thread.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
-> Moved to Off Topic
No idea what part of this is "tech".
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
