Hi,
I own a Dell Precision T3600 tower prebuilt (specs listed below). Although it is over 8 years old, it still works like a charm and has been my daily driver for the past 2 years. But recently, I am starting to see a few problems with it's graphics card (NVIDIA Quadro 2000 1GB).
Low-power games like Minecraft, Among Us and Factorio run fine with the default settings, but high-power games like BeamNG.Drive, Asetto Corsa and Cities Skylines are only playable with the lowest settings, and even that pins the GPU usage at 100%.
Recently, the computer shuts off under high loads like high-power games, video editing, CAD or machine learning. I believe this is because of the GPU overheating because the monitors blank out first, and then the lights on the keyboard turn off after a second or two.
Is this really because of the GPU? Is there anything I can do with the GPU to fix this temporarily (I just need it to work for school and programming. I can put off on gaming for now)?
I also want to buy a new GPU (after the prices go down). I want an RTX 3060, but which one would be the best for the specs I have without causing bottlenecks (My budget is $400 Canadian [after the prices go down]).
Computer Specs:
CPU: Intel Xeon E5-1620 8 cores, 3.6 GHz
RAM: 16GB DDR3  (4 x 4GB)
GPU: NVIDIA Quadro 2000 1GB
Motherboard: Dell OEM Motherboard
PSU: Dell 635 Watt PSU
Storage: 256GB SSD + 1TB HDD
Thanks in advance,
Amol
6 minutes ago, Doug_Dangger said:
Powering down during high gpu loads... I'm sure it's your power supply that's insufficient or is about to give up the ghost.
I did some calculations. The system doesn't really use more than 350 - 400 Watts under max load. Wouldn't the 625 Watt PSU be sufficient?
Just now, amolven said:
Oh yeah. I forgot to mention that in the post. It is pretty high. ~ 70 on idle and ~90 on load.
ok. Are you going to clean or replace the thermal paste or increase airflow to the gpu?
2 minutes ago, amolven said:
Do you know any good brand of thermal paste?
Almost any known brand of paste will be an improvement over 74c at idle. I wouldnt expect any machine gpu to work correctly if that's the idle temp.
Those are some very high temperatures, 70c idle is terrible, it is very possible the card is the problem and it is 100% overheating. I would repaste the GPU and clean it's heatsink and fan/fans out. If it stops overheating but is still powering off under load than it is most likely your PSU as usually a computer turning off under high load is caused by a faulty PSU. But you definitely no matter what need to repaste that GPU.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
Depends on your power supply.  Some power supplies will claim 800 watts of power but are pure trash inside and even trip at 1/2 of that load.  There are some power supplies that only say 500 watts but if it's a quality unit could even temporarily exceed those claims.
Maybe you should run a synthetic load test like Unigine.
Or rip out your side panel cover, put a big fan blowing air in your unit and do a stress test.  If your computer still shuts down despite tremendous airflow then it's likely your power supply.
