Best AIO for a given set of fans
Alkas
Hi,
I'm currently building a new gaming rig and trying to decide which AIO cooler I should pick. My problem is a bit specific, in that I already know that I will be using the Lian Li UNI fans instead of the ones that come with the AIO cooler. Specifically, I will be going for a 360 system and preferably white (so kraken and arctic liquid freezer would be out).
Maybe a more general question would be this: are you aware of any tests that compare different AIOs specifically in terms of their radiator+pump performance, e.g. by using the same set of fans?
Any AIO should work with any fans, they're all standard size. If you're going for aesthetics, I would recommend Corsair's new AIO, it looks really nice and has 33 LED's on the pump head. They also have a nice cooling system that is very efficient. They are quite expensive in white though.
I'm not sure if there is anyone testing different AIO's with the same fans but if you dig deep enough on YouTube I'm sure you'll find something
